Very Hot Topic (More than 50 Replies) Трансформаторы PARTRIGE (Прочитано 391 раз)
Batman
11.01.2010 :: 22:13:21
Тема создана с целью создания тарнсформатора с секционированием знаменитых Партриджей
кто что знает поделитьесь информацией !!!
сейчас собираю усилитель для баса 100вт мощьности по схеме DR 200 на  4 лампах EL34
в интернете нашел такую информацию:
Batman
Re: Трансформаторы PARTRIGE
Ответ #1 - 11.01.2010 :: 22:13:30
DR103 Specifications (Audio Brothers)
Input Line Voltages 100v, 117.5v, 225v, 250v AC
Power consumption 330 watts maximum
Fuse Ratings Mains (100 or 117.5v) 6.3A (T) slow blow
    (225 or 250v) 3.15A (T) slow blow
  H. T. (all) 3.15A (T) slow blow
Output Valves 4 matched EL34 (6CA7)
Preamp Valves V1, V2, V3 ECC83 (12AX7)(7025)
Preamp Valve V4 ECC81 (12AT7)(6201)
Output Power 100w RMS (min) into 8Ω
Loudspeaker Impedance 4Ω, 8Ω, or 16Ω
Dimensions W: 640mm (25.2"), D: 288mm (11.3"), H: 269mm (10.6")
Weight 20.5kg (45 pounds)
The DR103 Partridge Output Transformer
This is a wide bandwidth "hi fi" transformer, much more so than the normal guitar amp output transformers in wide use.
Primary Impedance (Raa) 1750Ω
Frequency Response (-3db) 3.6 hz - 112 khz (!)
Weight 3.2kg (7 pounds)
Heyboer Transformers in Michigan, USA, is now making Hiwatt-style OTs, using high-grade lams and winding patterns like the original. VHR is a good retail outlet for these.
Hammond is now making output transformers with normal 0-4-8-16 secondaries! Their model 1650TA is good for a 100 watt and 1650KA for a 50 watt.
Another possibility for new builds (not a drop-in replacement) is a generic Marshall replacement transformer like the New Sensor MOP-100.
Detailed research on old Partridges is available at IG Präzisions-Wickeltechnik: Partridge Transformers
The DR103 Partridge Power Transformer
For a DR103, the power transformer is less critical, and any quality unit which provides the following will work fine:
350 VAC @ 300mA (HT)
6.3 VAC CT @ 7.5A (Heaters)
50 VAC @ 50mA (Bias)
Unfortunately, the HT winding is an unusual voltage value, meant for a full wave bridge, and separate bias windings are also rare (as opposed to a Fender-style bias tap off the main HT secondary).
Heyboer Transformers in Michigan, USA, is now making Hiwatt-style PTs which have the same set of secondary windings as the original, but with an improved (higher) bias voltage winding. Again, VHR is a good retail outlet for these.
Note that this is currently available in either single 120v primary or dual 120v (switchable 120 to 240 volt only), and is therefore not a drop-in replacement. VHR & Heyboer are currently developing a drop-in replacement.
Another possibility is to use a JMP100 Marshall 100 watt replacement like the Hammond 290HX. NOTE: If you choose this option do NOT ground the secondary center tap, but rather tape and stow it unconnected. These specific Marshall replacement transformers are designed to be used with the Marshall "voltage doubler" power supply, and so the voltages also work out for a DR103. You will need also to adjust the bias supply resistor, as the bias supply on these is twice the stock Hiwatt value.
356 VAC @ 420mA (HT)
6.3 VAC CT @ 7A (Heaters)
100 VAC @ 50mA (bias)
For a 50 watt, a generic Marshall 50watt replacement transformer such as the Hammond 290GX will work fine:
300-0-300 VAC @ 250mA (HT)
6.3 VAC CT @ 5A (Heaters)
Batman
Ответ #2 - 11.01.2010 :: 22:15:57
PARTRIDGE TG5479
Raa      1750 Ohms
Inductance@50Hz      self-inductance@4,5H
10 Volts@100H
230 Volts@170H
Leakage Inductance @1,6kHz      P1+P2/S 1,9mH
P1/P2 1,1mH
Frequency-Respond      Datasheet
DC-resistance (primary)      (orange-black) 24,0 Ohms
(black-red) 25,3 Ohms
DC-resistance (secondary)      4 Ohms@0,29 Ohm
8 Ohms@0,38 Ohm
16 Ohms@0,50 Ohm
100 Volts@2,48 Ohm
self capacity of primary, CT and one side of secondary connected to core      ca. 330 pF
Batman
Ответ #3 - 12.01.2010 :: 13:35:07
... Неужели никто не изготавливал выходники с секционированием?
K O T
Ответ #4 - 12.01.2010 :: 14:03:43
Изготавливали и многие, только никто не знает как реализовано секционирование в трансформаторах PARTRIDGE.
По тем данным что ты выложыл, какбы о конструкции трансформатора можно только догадываться.
Batman
Ответ #5 - 12.01.2010 :: 16:34:10
Я понимаю что эти данные не полная информция) может кто видел оригинальные трансформаторы? или у кого нибудь есть снимки выходников по которым можно посмотреть как выполнено секционирование
Kostyan
Местоположение: Хабаровск
Ответ #6 - 12.01.2010 :: 16:42:14
А железо от партриджа у тебя есть? Если ты на кровельном железе даже золотом намотаешь ничего доброго не будет в итоге.
Batman
Ответ #7 - 12.01.2010 :: 16:52:37
я это прекрасно понимаю речь в данном топике идет о секционировании партриджей)
Ответ #8 - 12.01.2010 :: 20:04:41
Я практически не владею английским, может, чего и неправильно понимаю... Некоторые цифры вызывают большие сомнения. Озадачен
http://www.inmadout.com/download/pdf/tudr103.pdf
Пока ничего нового не нашёл...
« Последняя редакция: 12.01.2010 :: 20:19:46 от Наблюдатель »
Rus
Ответ #9 - 12.01.2010 :: 20:37:48
А что это еще за кусок первички дополнительный?
Batman
Ответ #10 - 12.01.2010 :: 20:42:55
) это и есть секционирование)
в середине одна полдовинка первички вторая разбросана между  нижней и верхней обмотками
спасибо за информацию
« Последняя редакция: 12.01.2010 :: 20:43:52 от Batman »
Ответ #11 - 12.01.2010 :: 20:57:21
Очень странные цифры: Primary Impedance (Raa) 1750Ω
Weight 3.2kg (7 pounds) Любой, кто мотал вых. трансы подтвердит, что транс от 3,6Гц Ужас будет весить минимум раза в 3-4 раза тяжелей. Озадачен Разве что этот транс для полутораваттного усилителя.
Далее: PARTRIDGE TG5479
Raa      1750 Ohms
10 Volts@100H
230 Volts@170H
P1/P2 1,1mH  Из этих данных ясно, что нижняя рабочая частота этого транса будет 65-70 Гц, транс собран без зазора. А столь низкая индуктивность рассеяния для гитарного транса избыточна и ничего не улучшит. Похоже, от Партриджа осталось одно имя. Или я неправ?
Batman
Ответ #12 - 12.01.2010 :: 21:44:38
эта информация с  сайта не помню ссылку но там есть еще и графики частот
Dr.Fox
%USERNAME%
Местоположение: Pandora
Ответ #13 - 13.01.2010 :: 06:43:59
обратитесь в аудиоинструмент) у них выходнки как раз от очень низкой до высокой частоты есть...думаю самому в 3.2г такое счастье не уместить... ИМХО
« Последняя редакция: 13.01.2010 :: 06:44:35 от Dr.Fox »
Freedom is slavery.
War is peace.
Ignorance is Strength.
Existence is suffering.
Rus
Ответ #14 - 13.01.2010 :: 11:48:39
Так может они намеряли такую частотку с мего-низкоимпедансным источником и на микроскопической мощности, и предусмотрительно об этом умолчали
Serchey
Ответ #15 - 13.01.2010 :: 11:50:57
А может и вообще не меряли - просто расчитали Улыбка
« Последняя редакция: 13.01.2010 :: 11:53:12 от Serchey »
Ответ #16 - 14.01.2010 :: 17:03:16
Не надо ничего мудрить. Обратитесь к Марку Фельдшеру на аудиопортале. Он разматывал горелый партридж Подмигивание
Ответ #17 - 14.01.2010 :: 17:14:18
Jimmy, может, ты расспросишь Марка, если не в лом? Вроде бы у вас есть контакт, в самом деле интересно.
Ответ #18 - 14.01.2010 :: 17:21:10
Влом по некоторым причинам(не потому что лень). Без обид. Зарегся и кинь ему личку. Он стопудово поделится.
« Последняя редакция: 14.01.2010 :: 17:23:09 от »
Batman
Ответ #19 - 20.01.2010 :: 13:54:53
никто не пишет  на аудиопортале что печально, уже начал сам мотать выходник не знаю пока что получиться
