Прошу прощения за обширную копипасту, ну очень она доступно написана.
http://geofex.com/tubeampfaq/TUBEFAQ.htmSo I went to the internet and searched for manufacturer's info on CC's. The makers themselves admit that carbon comps have excess noise, high drift, high pulse power, and high variability. They also have a high voltage coefficient of resistance. Voltage coefficient of resistance?? What's that?
That means that the resistance actually varies with the voltage across the resistor. The resistance is actually different if you put 100V across the resistance than if it's got 0V across it. What that means to us is that if you put a 50V DC level across a CC resistor and a 100V sine wave superimposed on that, the sine wave will be measurably distorted by the resistor itself. We have resistor distortion.
The distortion is pretty much pure second harmonic. In small amounts, you can't hear second harmonic as distortion, only a certain amount of "sweetening" or liquidity to the tone. That's what carbon comp resistor mojo really is - the resistors are distorting, but in a way our ears like.
The manufacturers also document that CC's have excess noise and bad drift with temperature and aging. That makes them a two-edged sword. Put everywhere in an amp, and they'll both sweeten the tone, and at the same time induce hiss. A little thought leads us to the following guidelines for using carbon comps for tone mojo:
1. high voltage across the resistor is necessary, in the range of 100V on up
2. large signal swings across the resistor are needed - ideally, a large fraction of the static DC voltage so you have signal swings of 50 to 100V too.
3. only positions in the amp that have both high DC voltage and wide signal swings as in 1 and 2 will give you enough resistor distortion to benefit from; other places should be chosen for low noise and/or economy.
4. resistor power rating should be the minimum needed to work for a reasonable life in the circuit to maximize resistor distortion. Maybe a good guideline is that the dissipation should be selected to be as close to two times the average dissipation as possible.
5. as a corollary to the power guideline, we should be prepared to replace CC's every few years as the life at high temp makes them drift and get noisy(-er).
