Normal Topic 1W poweramp (Прочитано 183 раз)
armkon
1W poweramp
15.04.2014 :: 16:01:01
Hello, sorry for english toppic but i have a problem. I see a lot of smart guys in here so i think that i will ask for something.
I have design a little PA 1W or something like this. It will be powered by nixie PSU.
It will use normal input stage then cathodyne on 1 ecc83 tube and signal will be outputed from ecc82 tube thru transformer.
It will be used to connect external preamp and 9v eq betwean it and PA. I think that ecc82 tube will be drived with good signal streanght that will be loose on eq and will go up on that first stage...
Or it's bad idea?
Maestro
Местоположение: Россия, г.Киров (обл.)
Re: 1W poweramp
Ответ #1 - 15.04.2014 :: 16:50:28
Ёмана! упражняемся в буржуйском )
@ armkon
Put here what type preamp(or scheme) you want to use, and type Eq(or scheme) for full image of your plan. I think it's would be better to understand your question for people here.
ФёдорЫч
Long live Rock-n-Roll!!!
Местоположение: MSK reg.
Re: 1W poweramp
Ответ #2 - 15.04.2014 :: 16:58:41
Seems to me , the idea is quite strange. Why did you take a decision to use this 1watt PA . Do you need  to have output signal to be distorted  ( like guitar amp sounding ) or clean ?  Your schematic diagram has the error . Feedback resistor R11 must to be connected to point R1-C1-R7.
toiler
Re: 1W poweramp
Ответ #3 - 15.04.2014 :: 17:18:50
И не надо на сетках и катодах выходных ламп писать 300V.
armkon
Re: 1W poweramp
Ответ #4 - 15.04.2014 :: 17:27:37
IT must act like normal guitar amp. preamp will be higain something engl like, i want to use it for playing at house. As Post EQ i want to use MXR EQ.
Sorry for my mistake with that 300V...
« Последняя редакция: 15.04.2014 :: 17:45:57 от armkon »
ФёдорЫч
Re: 1W poweramp
Ответ #5 - 15.04.2014 :: 17:42:19
Triod in PP output stage is not for guitar good sounding amps. The sound will be dull and rigid.  Pls, look here
http://www.liegamp.com/pdf/stimer.pdf ;
« Последняя редакция: 15.04.2014 :: 17:51:06 от ФёдорЫч »
Gregg
Re: 1W poweramp
Ответ #6 - 15.04.2014 :: 18:26:27
I agree with you that push pull small signal triode based amp is not a good idea but single ended pentode or triode design is even worse.
armkon
Re: 1W poweramp
Ответ #7 - 15.04.2014 :: 18:47:46
So what is better idea ? Then push pull as poweramp for playing at home with good sound quality?
I can build a TBA820 amp like in engl e530.
Waiting for your sugesions  Смех
Gregg
Re: 1W poweramp
Ответ #8 - 15.04.2014 :: 18:52:02
My advice is get some 6П30Б or 6П30Б-Р subminiature pentodes from ebay or elsewhere and make a regular push-pull class AB power amp as are most of the guitar amps. Depending on the anode voltage you'll be able to get somewhere between 2 and 6 Watts RMS before clipping.
ФёдорЫч
Re: 1W poweramp
Ответ #9 - 15.04.2014 :: 18:56:29
Gregg писал(а) 15.04.2014 :: 18:26:27:
http://vk.com/gtlab
The samples are here. SE amp , 2,2 watts . This amp
http://vk.com/albums183961254?z=photo183961254_305267337%2Fphotos183961254
« Последняя редакция: 15.04.2014 :: 19:09:25 от ФёдорЫч »
armkon
Re: 1W poweramp
Ответ #10 - 15.04.2014 :: 19:08:37
[/quote]
http://vk.com/gtlab
[/quote]
i don't see anything when i going in to this page
ФёдорЫч
Re: 1W poweramp
Ответ #11 - 15.04.2014 :: 19:12:53
In audio (аудиозаписи) , song BB stars-slow  and the next (below)
Re: 1W poweramp
Ответ #12 - 15.04.2014 :: 19:19:06
ФёдорЫч, тем кто не присутствует в контакте не посмотреть, я например не нашел.
ФёдорЫч
Re: 1W poweramp
Ответ #13 - 15.04.2014 :: 19:21:57
А я не умею по другому Печаль Печаль Только через "В Контакте"
« Последняя редакция: 15.04.2014 :: 19:23:21 от ФёдорЫч »
Re: 1W poweramp
Ответ #14 - 15.04.2014 :: 19:30:39
ФёдорЫч
Re: 1W poweramp
Ответ #15 - 15.04.2014 :: 19:56:30
I can to send samples  to e-mail address. If you want.
armkon
Re: 1W poweramp
Ответ #16 - 15.04.2014 :: 20:11:26
I have send you PM, waiting Улыбка
armkon
Re: 1W poweramp
Ответ #17 - 15.04.2014 :: 20:14:42
What do you think? It's worth to try? How to make this PA better then in is in this configuration ? Круглые глаза
PA like fireflywork good for me, i know it's not the best think that i can make but it's ok and better then making an ic based pa...
« Последняя редакция: 16.04.2014 :: 06:16:21 от armkon »
armkon
Re: 1W poweramp
Ответ #18 - 16.04.2014 :: 09:55:49
A little layout for this push pull amp:
Don't look at input tracks.
If anyone can check it please any help will be welcome Улыбка Подмигивание
« Последняя редакция: 16.04.2014 :: 09:56:37 от armkon »
Re: 1W poweramp
Ответ #19 - 16.04.2014 :: 10:41:27
armkon, try to check this schematic of the power amp, I think it's better solution for the guitar sound.
http://forum.guitarplayer.ru/index.php?topic=253490.msg7372516#msg7372516
