Gizma почитай отзывы на г.централе, фильтруя пиарщиков что ставят оценку 10.10.10.10.10!!
"But it sounds like TOTAL SHIT! I'm using a warlock with only a stock pick-up, but I A/B'd the GP3 to my JMP-1, which utterly KICKED ITS ASS. That's right, my 3 stage tube/solid state bridge-rectifer diode clipping 150V JMP-1 sounds WAY better. Why? Because its CRUNCHY. If you know the JMP-1, you know what the bass shift does, and the GP3 does the same thing times 10. In other words, the farty flappiness induced by the voicing in the GP3 CANNOT be dialed out, and that same fartiness is 10 times fartier than the bass shift fart on the JMP-1. Even with the treble at half or maxed, mids maxed, bass totally attenuated, EQ with slight upside-down smile or off, brite on, boost on, and gain/boost at half or maxed, the thing would just not crunch on either ch 2 or 3. Only fart. YUK! I would never record or jam out with it, no way. Is it quiet? I suppose. Lacking sustain? Perhaps. My JMP-1 has a little more sustain. I've played the new JCM 2000 series and it's farty too, but less farty than this. Oh yeah, there was no added extra distortion/tone when manipulating the master volume (in conjunction with preamp vol. both gotta be cranked up) as with an out board pwr amp, and in fact, going past 3 o'clock (vol of 2 or 3 and mast vol) produced a sickly gurgling sound. Worst voicing I have ever heard."
"Sound Quality : 1 BUT IT SOUNDS LIKE ASS! This preamp would be appreciated by fools like Limp Bizkit, Linkin Park, and other lame nu-metal posers out there. It's perfect for that thin, toneless, wannabe-brutal crap. You can tweak all you want, and the sound will remain stale."
